Garmin Messenger App
WARNING
The inReach® features of the Garmin Messenger™ app on your phone, including SOS, tracking, and inReach Weather, are not available without a connected inReach device and an active inReach service plan. Always test the app outdoors before using it on a trip.
CAUTION
The non-satellite messaging features of the Garmin Messenger app on your phone should not be solely relied upon as a primary method to obtain emergency assistance.
NOTICE
The app works over both the internet (using a wireless connection or cellular data on your phone) and the satellite network (using an inReach device). If you are using cellular data, your paired phone must be equipped with a data plan and be in an area of network coverage where data is available. If you are in an area without network coverage, you must have an active inReach service plan for your device to use the satellite network.
You can use the app to message other Garmin Messenger app users, including friends and family without Garmin® devices. Anyone can download the app and connect their phone, allowing them to communicate with other app users over the internet (no login is required). App users can also create group messaging threads with other SMS phone numbers. New members added to the group message can download the app to see what others are saying.
Messages sent using a wireless connection or cellular data on your phone do not incur data charges or additional charges on your inReach service plan. Messages received may incur charges if message delivery is attempted over both the satellite network and the internet. Standard text messaging rates for your cellular data plan apply.
You can download the Garmin Messenger app from the app store on your phone (garmin.com/messengerapp).
Using the Garmin Messenger App
CAUTION
The non-satellite messaging features of the Garmin Messenger app alone should not be relied on as a primary method to obtain emergency assistance.
NOTICE
To use the Garmin Messenger app on your Tread® navigator, it must be connected to the Tread app and the Garmin Messenger app on your compatible phone using Bluetooth® technology (Garmin Messenger App).
The Garmin Messenger app on your navigator allows you to view, compose, and reply to messages from the Garmin Messenger app on your phone.
  1. From the home screen, select Garmin Messenger.
  2. If this is your first time using the Garmin Messenger feature, scan the QR code with your phone, and follow the on-screen instructions to complete the pairing and setup process.
  3. On your navigator, select an option:
    • To compose a new message, select New Message, select one or more recipients, select Next, and compose a message.
    • To view a conversation, scroll down, and select a conversation.
    • To reply to a message, select a conversation, select Reply, and compose a message.
      TIP: You can select Send location icon to send a message with your current location.
    • To share a location, select Plus icon > Location, search for a location, and select Select to add it to the message.
    • To send an automated message with your arrival time while navigating to a destination, select Plus icon > Arrival Time.
Creating a Post in the Garmin Messenger App
CAUTION
You can send a post message to multiple recipients at once, where each recipient receives the message individually without seeing replies from others. Messages sent to more than five contacts, or to email addresses and Tread 2 addresses, are sent as post messages.
  2. Select Wrench > Create a New Post.
  3. Select one or more recipients.
  4. Select Next.
  5. Compose a message.
    TIP: You can select Send location icon to send a message with your current location. You can select Plus icon to share a location or send an automated message with your arrival time while navigating.
Deleting Messages in the Garmin Messenger App
  2. Select an option:
    • To delete an individual message, select a conversation, select a message, and select Delete.
    • To delete an entire message thread, select Wrench > Delete Messages, select a message thread, and select Delete.
GUID-5AE59F95-4268-47C5-8D27-DC4B4F41E230 v3
December 2025
