Changing the Fuse in the Fuse Cable
NOTICE
When replacing the fuse, verify the replacement fuse is fully inserted into the fuse housing. The vehicle power cable does not work unless it is assembled correctly.
If your device does not charge in your vehicle, you may need to replace the fuse located on the red system power cable.
  1. Lift up the cover from the top of the fuse housing.
  2. Insert a new 3 A fuse.
  3. Replace the cover on the fuse housing.
GUID-5AE59F95-4268-47C5-8D27-DC4B4F41E230 v3
December 2025
