Adventurous Routing
WARNING
Always use your best judgment and exercise common sense when making navigational decisions. Always carefully compare information displayed on the device to all available navigation sources, including weather conditions, maps, street and trail signs and conditions, waterway restrictions, and other factors that may affect safety. Always defer to posted signs and conditions and do not follow the route suggestions if they suggest an illegal course or would put you in an unsafe situation.
Garmin Adventurous Routing™ is a special route calculation mode designed to prefer routes featuring more hills and winding roads. You can choose a level of adventurous routing to fine-tune the route calculation to your preferences. If you prefer winding roads and hills even if it increases travel time, distance or fuel consumption, choose a higher level of adventurous routing.
For each vehicle profile, you can select a level of adventurous routing as the default route calculation mode (Editing a Vehicle Profile). Regardless of the current vehicle profile, you can always select Adventurous routing to use adventurous routing when starting, planning, or editing a route.
GUID-5AE59F95-4268-47C5-8D27-DC4B4F41E230 v3
December 2025
