Device and Privacy Settings
Select Settings > Device.
About
Displays the software version number, the unit ID number, and information on several other software features.
Screen Lock
Sets options to require a Personal Identification Number (PIN) each time you turn on the navigator (Enabling the Screen Lock).
Regulatory
Displays regulatory markings and information.
EULAs
Displays the end-user license agreements.
NOTE: You need this information when you update the system software or purchase additional map data.
Software Licenses
Displays software licensing information.
Device Data Reporting
Shares anonymous data to improve the device.
Travel History
Allows the device to store a record of the places you go. This allows you to view the trip log, use the Trip History feature, and use myTrends™ suggested routes.
Reset
Allows you to clear your travel history, reset settings, or delete all user data.
To prevent unauthorized use of your device, you can enable the Screen Lock feature, which requires a Personal Identification Number (PIN). When enabled, you must enter the PIN to unlock the screen each time you turn on the device.
NOTICE
If you enable the Screen Lock feature, Garmin® Support cannot retrieve the PIN or access your device. It is your responsibility to provide the PIN to anyone authorized to use the navigator.
  1. Select Settings > Device > Screen Lock.
  2. Select an option:
    • To enable the screen lock and set a new PIN, select Require PIN, and enter a PIN number.
    • To change your PIN number, select Change PIN, and enter a PIN number.
    • To disable the screen lock, clear the Require PIN check box.
GUID-5AE59F95-4268-47C5-8D27-DC4B4F41E230 v3
December 2025
