Great Rides
WARNING
This feature allows you to follow rides and routes generated by third parties. Garmin® makes no representations about the accuracy, reliability, completeness or timeliness of routes generated by third parties. Any use or reliance on such routes is at your own risk.
You can use the Great Rides feature to bookmark and navigate popular rides. You can rate rides and share photos using the Tread® app on your smartphone.
Bookmarking a Ride
You can view and bookmark rides using the Tread app on your smartphone. Bookmarked rides automatically sync with your Tread 2 navigator while it is connected to the Tread app.
  1. From the Tread app on your smartphone, select Menu > Great Rides.
  2. Select an option:
    • To view a list of popular rides in your region, select Top Rides.
    • To view a list of nearby rides, select Nearby.
  3. Select a ride.
  4. Select Add Bookmark.
Synchronizing Great Rides
Bookmarked rides synchronize automatically when you open the Great Rides app on your Tread 2 navigator while you are connected to the Tread app on your smartphone. You can also synchronize data manually at any time.
  1. Select Apps icon > Great Rides.
  2. If necessary, select Synchronize symbol.
Navigating a Bookmarked Ride
Before you can navigate to a bookmarked ride, you must synchronize the Great Rides app on your Tread 2 navigator with the Tread app on your smartphone (Synchronizing Great Rides).
  2. Select a ride.
  3. Select the starting point for your ride, and select Go!.
  4. Select the next destination, and select OK.
    The device calculates a route to the starting point you selected.
  5. Select Start.
After you navigate a bookmarked ride, you can rate the ride and share photos using the Tread app on your smartphone.
GUID-5AE59F95-4268-47C5-8D27-DC4B4F41E230 v3
December 2025
