Radio
NOTE: Before you can use the Radio app, you must install a Group Ride accessory. Go to garmin.com to purchase a Group Ride accessory.
TIP: The Radio app is not available in all regions.
You can use the Radio app to create radio presets, select a radio channel, and select squelch codes. To use this feature, you must connect the device and the antenna to the Group Ride mount. The Tread® 2 device configures radio settings automatically when you join or create a group ride.
GUID-5AE59F95-4268-47C5-8D27-DC4B4F41E230 v3
December 2025
