Calibrating the Compass
NOTICE
Calibrate the electronic compass outdoors. To improve heading accuracy, do not stand near metal objects or objects that influence magnetic fields, such as vehicles, electronic devices, buildings, or overhead power lines.
When your device is connected to the mount, it uses GPS data to determine your compass heading. When you remove the device from the mount, it uses a built-in compass to show your heading.
Each time you disconnect your device from the mount, you may need to calibrate the compass.
If you experience irregular compass behavior, for example, after moving long distances or after extreme temperature changes, you can manually calibrate the compass to improve accuracy.
  1. Disconnect the device from the mount and move away from objects that influence magnetic fields.
  2. From the main menu, select Apps icon > ABC > Wrench > Calibrate Compass.
  3. Follow the on-screen instructions.
GUID-5AE59F95-4268-47C5-8D27-DC4B4F41E230 v3
December 2025
