Adding Portable Propane Tanks
NOTICE
This device is designed to provide route suggestions only. It is your responsibility to know and comply with all laws, regulations, and other restrictions in your jurisdiction related to the addition of propane tanks to your vehicle.
NOTE: This feature is only available with certain vehicle profiles.
When you add your propane tanks to your vehicle profile, the device avoids routing through areas with propane tank restrictions that may affect your route. The device also alerts you when you approach areas that require you to shut off your propane tanks.
  1. From the vehicle profile, select Propane tank symbol > Add Portable Tank.
  2. Enter the weight of the propane tank, and select Save.
GUID-5AE59F95-4268-47C5-8D27-DC4B4F41E230 v3
December 2025
