Charging the inReach Device
NOTICE
To prevent corrosion, thoroughly dry the USB port, the weather cap, and the surrounding area before charging or connecting to a computer.
NOTE: The device does not charge when it is outside the approved temperature range (Specifications).
  1. Lift the weather cap Callout number 1.
    Closeup of the USB port with callouts
  2. Plug the small end of the power cable into the charging port Callout number 2 on the device.
  3. Plug the other end of the power cable into a compatible AC power adapter.
  4. Plug the AC power adapter into a standard wall outlet.
    The device displays the current battery charge level.
GUID-5919E4DF-BE2C-4897-AE03-3BF5B0AD3ACA v5
April 2025
