Requesting an inReach Weather Forecast
For best results, you should ensure your device has a clear view of the sky when you request an inReach® weather forecast.
  1. From the home page, press Left arrow or Right arrow to scroll through the main menu options.
  2. Select Weather.
  3. Press OK to open the options menu.
  4. Select Update Forecast.
  5. If necessary, select a forecast type.
    NOTE: For best results, you should request a marine forecast for a location away from shore and over a large body of water. Marine forecasts are not available for land locations or inland lakes.
The device sends a request for the forecast. It may take several minutes to receive the weather forecast data. After the device finishes downloading the data, you can view the forecast at any time until all of the information in the forecast has expired. You can also update the forecast at any time.
NOTE: Updating a forecast incurs data charges or additional usage charges.
GUID-5919E4DF-BE2C-4897-AE03-3BF5B0AD3ACA v5
April 2025
