Tips for Missing Running Dynamics Data If running dynamics data does not appear, you can try these tips. Make sure your Garmin® device supports running dynamics. For more information, go to www.garmin.com/runningdynamics. Pair the HRM-Pro™ Plus accessory with your Garmin device again, according to the instructions. Make sure you are paired using ANT+®, rather than Bluetooth®. If the running dynamics data display shows only zeros, make sure the accessory is worn right-side up. NOTE: Ground contact time and balance appears only while running. It is not calculated while walking. Parent Topic: TroubleshootingHomeDevice InformationTroubleshootingTips for Missing Running Dynamics Data
