Accessing Stored Heart Rate Data
If you save a timed activity without downloading stored heart rate data, you can download the data from the
HRM-Pro™ Plus device later.
NOTE:
Your
HRM-Pro Plus device stores up to 18 hours of activity history. When the heart rate monitor memory is full, your oldest data is overwritten.
- Put on the heart rate monitor.
- From your Garmin® device, select the History menu.
- Select the timed activity you saved while you were wearing the HRM-Pro Plus device.
- Select Download Heart Rate.
Your Garmin device generates a new activity file with heart rate data. You may need to manually import the new file to your Garmin Connect™ account.
Parent Topic: Heart Rate Storage for Timed Activities
