Replacing the Heart Rate Monitor Battery
Remove the sleeve
from the heart rate monitor module.
Press down on the tab
, and rotate the battery door counter-clockwise.
NOTE: Some models do not have the tab. You still have to rotate the battery door counter-clockwise.The arrow moves from locked
to unlocked
- Remove the battery door.
Gently pull up the battery tab
, and remove the battery from the battery door.
NOTE: You can also use a magnet to remove the battery.
- Wait 30 seconds.
- Insert the new battery in the door with the negative side facing up.
Align the battery door with the unlock icon.
NOTE: The battery door must be flush with the heart rate monitor module.
- Rotate the battery door clockwise until the marker points to locked.
- Replace the sleeve.
Parent Topic: Troubleshooting
