Fitness_Notes
Always consult your physician before you begin or modify any exercise program.
Do not use a sharp object to remove user-replaceable batteries.
Contact your local waste disposal department to properly recycle the batteries. Perchlorate Material – special handling may apply. Go to www.dtsc.ca.gov/hazardouswaste/perchlorate.
The pin tool is sharp. Use with care.
Do not use a sharp object to clean the device.
Avoid chemical cleaners, solvents, and insect repellents that can damage plastic components and finishes.
Avoid pressing the keys under water.
Avoid extreme shock and harsh treatment, because it can degrade the life of the product.
Thoroughly rinse the device with fresh water after exposure to chlorinated or salt water environments.
Thoroughly rinse the device with fresh water after exposure to chlorine, salt water, sunscreen, cosmetics, alcohol, or other harsh chemicals. Prolonged exposure to these substances can damage the case.
Always wipe the device dry after cleaning.
Always wipe the device dry after cleaning or use, and store it in a cool, dry place.
Before you attempt to replace the battery, carefully read the instructions in the owner's manual.
The device is intended for surface swimming. Scuba diving with the device may damage the product and will void the warranty.
You must unsnap and remove the module before washing the strap.
Calibrate the electronic compass outdoors. To improve heading accuracy, do not stand near objects that influence magnetic fields, such as vehicles, buildings, and overhead power lines.
The device is water resistant to IEC Standard 60529 IPX7. It can withstand immersion in 1 meter of water for 30 minutes. Prolonged submersion can cause damage to the device. After submersion, be certain to wipe dry and air dry the device before using or charging.
The heart rate monitor may cause chafing when used for long periods of time. To alleviate this issue, apply an anti-friction lubricant or gel to the center of the module where it contacts your skin. Do not apply anti-friction gel or lubricant on the electrodes. Do not use gels or lubricants that contain sunscreen.
