Deleting a Profile NOTE: You cannot delete a profile while it is in use. Press MENU twice to open the main menu. Select Setup > Profiles. Select a profile. Select Delete. Parent Topic: Profiles
Deleting a Profile NOTE: You cannot delete a profile while it is in use. Press MENU twice to open the main menu. Select Setup > Profiles. Select a profile. Select Delete. Parent Topic: ProfilesHomeCustomizing the DeviceSetup MenuProfilesDeleting a Profile
