Changing the Units of Measure
  1. Press MENU twice to open the main menu.
  2. Select Setup > Units.
  3. Select an option:
    • To change the unit of measure for speed and distance, select Speed/Distance.
    • To change the unit of measure for vertical speed, select Vertical Speed.
    • To change the unit of measure for elevation, select Elevation > Elevation.
    • To change the unit of measure for depth, select Elevation > Depth.
    • To change the unit of measure for temperature, select Temperature.
    • To change the unit of measure for pressure, select Pressure.
  4. Select a unit of measure.
GUID-5724F4C0-7557-4C51-BF07-54A567FA4600 v3
February 2025
