Using the Flashlight
WARNING
This device may have a flashlight that can be programmed to flash at various intervals. Consult your physician if you have epilepsy or are sensitive to bright or flashing lights.
NOTE: Using the flashlight can reduce battery life. You can reduce the brightness or flash frequency to extend the life of the battery.
  1. Press MENU twice to open the main menu.
  2. Select Flashlight > ENTER.
    NOTE: You may need to add this application to the main menu before you can select it (Customizing the Main Menu).
  3. If necessary, use the brightness slider to adjust the brightness.
  4. If necessary, select a different flash type.
    0
    No strobe, constant beam.
    1 through 9
    Number of strobes per second.
    SOS
    Emergency strobe.
    NOTE: Wi‑Fi®, Bluetooth®, and ANT‍+® connections are disabled in SOS mode.
GUID-5724F4C0-7557-4C51-BF07-54A567FA4600 v3
February 2025
