Viewing an Active Weather Map
To view an active weather map, your navigator must be connected to your phone.
While your navigator is connected to a phone or Wi‑Fi® network with internet access, you can view a live weather map showing weather radar, cloud cover, temperature, or wind conditions.
  1. Press MENU twice to open the main menu.
  2. Select Active Weather.
  3. Press Left arrow or Right arrow to select a weather map tab.
    NOTE: Some options may not be available in all areas.
    • To view a weather radar, select Weather radar.
    • To view cloud coverage, select Clouds.
    • To view temperatures, select Temperature map.
    • To view wind speeds and directions, select Wind conditions.
    The selected data appears on the map. The navigator may take a few moments to load the weather map data.
  4. Select an option:
    • To zoom in or out on the map, press Plus or Minus.
    • To pan up, down, left, or right on the map, press Down arrow to enter panning mode, and use the directional pad.
GUID-5724F4C0-7557-4C51-BF07-54A567FA4600 v3
February 2025
