Adjusting Additional Audio Settings for a Zone
  1. Select Menu button > SETTINGS.
  2. Select ZONE.
  3. Select a zone.
  4. Select one or more options:
    • To limit the maximum volume output of this zone, select VOLUME LIMIT, and adjust the level.
    • To adjust the right and left speaker balance of this zone, select BALANCE, and adjust the balance.
    • To reduce the power output to the external amplifier associated with this zone, select EXT. AMP GAIN, and adjust the gain level.
    • To reduce the power output to the internal amplifier associated with this zone, select INT. AMP GAIN, and adjust the gain level.
      NOTE: This setting is available only for zones associated with an internal amplifier, typically zones 1 and 2.
    • To change the output of this zone from stereo to mono, select MONO.
      NOTE: The mono setting is useful if a listening position is closer to one speaker than the other and predominantly hear only that channel. The mono setting combines both channels in each speaker in the zone.
GUID-56980C9B-0008-49B0-9193-091DD5268F2D v10
January 2025
