Stereo Controls
Front view of the device
Dial
  • Turn to adjust the volume.
  • When adjusting the volume, press to switch between zones.
  • Turn to move through the menus or adjust a setting.
  • When in a menu, press to select the highlighted option.
  • Press and hold to activate certain functions such as opening the radio presets or muting all connected stereos from the mute screen (Muting all Connected Stereos).
Power button
  • Press to turn on the stereo.
  • Press to mute the audio.
  • Press and hold to turn off the stereo or all stereos on the network.
  • Press and hold for longer than 10 seconds to reset the stereo.
Menu button
  • Press to open the menu.
  • Press to return to the previous screen from the menu.
  • Press and hold to exit the menu.
Source button
Press to change the source.
TIP: You can turn the dial to browse, and press the dial to select the source.
Press and hold to open the GROUPS menu when connected to a Fusion PartyBus™ network (Fusion PartyBus Networking).
Back button
  • Press to skip to the beginning of the track or to the previous track, when using an applicable source.
  • Press and hold to rewind the track, when using an applicable source.
  • AM/FM source:
    • Press to tune to the previous station or preset.
    • Press and hold for faster tuning (manual mode only).
  • AUX: Press to decrease the gain.
  • SiriusXM source:
    • In Live Mode, press to tune to the previous station or preset.
    • In Live Mode, press and hold for faster tuning, in Manual mode only.
    • In Replay Mode, press to skip to the previous track.
    • In Replay Mode, press and hold to rewind the current track.
  • DAB source:
    • Press to return to the previous DAB station in the ensemble. When you reach the beginning of the current ensemble, the stereo automatically changes to the last available station in the previous ensemble.
    • Press and hold to return to the previous DAB ensemble.
Play and pause button
  • Press to pause or resume media playback.
  • AM/FM source:
    • Press to cycle through the tuning modes (Auto, Manual, and Preset).
    • Press and hold to save the selected station as a preset.
  • SiriusXM source:
    • Press and hold to switch between Replay Mode and Live Mode.
    • In Live Mode, press to cycle through the tuning modes (Manual, Category, and Preset).
    • In Replay Mode, press to pause and play.
  • DAB source:
    • Press and hold to scan for DAB stations.
    • Press to switch between manual tuning mode and presets.
Forward button
  • Press to skip to the next track or station, when using an applicable source.
  • Press and hold to fast-forward, when using an applicable source.
  • AM/FM:
    • Press to tune to the next station or preset.
  • AUX: Press to increase the gain.
  • SiriusXM source:
    • In Live Mode, press to tune to the next station or preset.
    • In Replay Mode, press to skip to the next track, if applicable.
    • In Replay Mode, press and hold to fast-forward the current track, if applicable.
  • DAB source:
    • Press to advance to the next DAB station in the ensemble. When you reach the end of the current ensemble, the stereo automatically changes to the first available station in the next ensemble.
    • Press and hold to advance to the next DAB ensemble.
GUID-56980C9B-0008-49B0-9193-091DD5268F2D v10
January 2025
