Power Cable Extensions
If necessary, the power cable can be extended using the appropriate wire gauge for the length of the extension.
Wiring diagram with callouts
Callout number 1
Splice
Callout number 2
  • Up to 4.6 m (15 ft.): 10 AWG (5.26 mm2) extension wire
  • Up to 7 m (23 ft.): 8 AWG (8.36 mm2) extension wire
  • Up to 11 m (36 ft.): 6 AWG (13.29 mm2) extension wire
Callout number 3
Fuse (15 A)
Callout number 4
20.3 cm (8 in.)
Callout number 5
Battery
Callout number 6
20.3 cm (8 in.)
Callout number 7
11 m (36 ft.) maximum extension
GUID-563B38D8-74B2-49FE-84EA-A4CFF0E611E2 v8
January 2025
