Touchscreen Controls for a Connected Computer
NOTICE
To prevent corrosion due to moisture, you must use Garmin® GPSMAP® accessory cables when connecting the chartplotter to the computer. Using different cables voids your warranty.
You can connect the chartplotter to a computer to see the computer screen on the chartplotter touchscreen and control the computer using the chartplotter touchscreen. To see the computer screen, you must connect the computer to the HDMI IN port. To control the computer, you must connect the computer to the USB port.
The Garmin HDMI® accessory cable (010-12390-20) is 4.5 m (15 ft) long. If you need a longer cable, you should use an active HDMI cable only. You need an HDMI coupler to connect the two HDMI cables.
The Garmin USB accessory cable (010-12390-10) is 4.5 m (15 ft) long. If you need a longer cable, you should use a USB hub or USB repeater extension cable only.
You must make all cable connections in a dry environment.
Block diagram with callouts
Devices
Item
Device
Callout number 1
Computer
Callout number 2
GPSMAP chartplotter
Connections
From
To
Cable
Callout number 1
Computer's HDMI OUT port
Callout number 2
Chartplotter's HDMI IN port
Garmin HDMI Cable
Callout number 3
Chartplotter's USB port
Callout number 4
Computer's USB port
Garmin USB Cable
GUID-563B38D8-74B2-49FE-84EA-A4CFF0E611E2 v8
January 2025
