My transceiver and watch lose connection underwater
If your watch and transceiver communicate on the surface but lose communication underwater, you can try these tips.
Adjusting the Transceiver Power Setting
NOTE: Increasing the power setting increases the audible noise and transmission range of the transceiver and decreases its battery life.
  1. On the paired Descent™ dive computer, from the Dive Setup menu, select Dive Network & Air Integration > Transmitters.
  2. Select a paired transceiver.
  3. Select Set Transmit Power.
  4. Enter the transceiver ID.
    NOTE: The transceiver ID is printed on the housing.
  5. Select an option.
GUID-55C588E7-3BD7-436C-B442-84E4388D43E2 v5
August 2026
