Descent T2 Device Care
Do not grip the regulator or the device to move, carry, or adjust the air tank.
Do not remove the safety plug from the base of the device.
Do not use a sharp object to clean the device.
Avoid chemical cleaners, solvents, and insect repellents that can damage plastic components and finishes.
Thoroughly rinse the device with fresh water after exposure to chlorine, salt water, sunscreen, cosmetics, alcohol, or other harsh chemicals. Prolonged exposure to these substances can damage the case.
Avoid extreme shock and harsh treatment, because it can degrade the life of the product.
Do not store the device where prolonged exposure to extreme temperatures can occur, because it can cause permanent damage.
Discontinue use if the device is damaged or if it is stored at a temperature outside the specified storage temperature range.
Discontinue use if there is water ingress into the battery compartment. Even small amounts of water can cause corrosion of the electrical contacts.
Inspect all o-rings before installing the device, flow restrictor, or air spool, and verify they are clean and undamaged. Replace worn or damaged o-rings as needed.
Cleaning the Transceiver
- After each dive, rinse the transceiver with fresh water to remove salt and debris.
- If necessary, clean the transceiver with a soft cloth.
Replacement Parts
Replacement parts are available for this device. Contact your Garmin® dealer or go to garmin.com for more information.
