LED Light Control and Configuration Using the ActiveCaptain App
You can connect your mobile device to a wireless router or wireless access point on the same network as the stereo. When connected to the stereo in this manner, you can use the ActiveCaptain® app to configure and control lights connected to a Garmin Spectra™ LED control module. If the stereo and LED control module are connected to the same NMEA 2000® network as a compatible chartplotter, you should connect the ActiveCaptain app to the chartplotter instead of the stereo so you can use the full features included in the app in addition to the lighting controls. See the owner's manual for the chartplotter for instructions.
NOTE: Before you can connect your mobile device to the stereo, you must connect the stereo to a wireless router using an Ethernet cable.
GUID-53FC9B2D-25AD-45AB-A2A1-50C08CBD5001 v7
September 2024
