Sharing Data with Garmin Share
Before you can use this feature, you must have Bluetooth® technology enabled on both compatible devices, and they must be within 3 m (10 ft.) of each other. When prompted, you must also consent to share your data with other Garmin® devices using Garmin Share.
Your Forerunner® watch can send and receive data when connected to another compatible Garmin device (Receiving Data with Garmin Share). You can also transfer your data between different devices. For example, you can share a favorite course from your Edge® bike computer to your compatible Garmin watch.
  1. From the watch face, press Upper-right button.
  2. Select Garmin Share > Share.
  3. Select a category, and select one item.
  4. Select an option:
    • Select Share.
    • Select Add More > Share to select more than one item to share.
  5. Wait while the device locates compatible devices.
  6. Select a device.
  7. Confirm the six-digit PIN matches on both devices, and select Check mark.
  8. Wait while the devices transfer the data.
  9. Select Share Again to share the same items with another user (optional).
  10. Select Done.
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
