Recording an Ultra Run Activity
  1. From the watch face, press Upper-right button.
  2. Select Activities > Running > Ultra Run.
  3. Press Upper-right button to start the activity timer.
  4. Start running.
  5. Press Lower-right button to record a lap and start the rest timer.
    TIP: You can configure how the Auto Rest setting records rest splits and laps (Ultra Run Auto Rest Settings).
  6. When you are done resting, press Lower-right button to resume running.
  7. Press Middle-left button or Lower-left button to view additional data screens (optional).
  8. After you complete your activity, press Upper-right button, and select Save.
You can customize the options for automatically starting and stopping the rest timer for the Ultra Run activity.
Status
Enables automatically recording rest splits.
Rest Start
Automatically starts the rest timer when you stop running. You can use the Manual Only option to start the rest timer only when you press Lower-right button.
Rest End
Sets the pace required to end a rest split.
Minimum Time
Sets the amount of time before a rest split starts or ends.
Lap Key
Sets the Lower-right button button to record a lap and start the rest timer, start the rest timer only, or record a lap only.
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
