Customizing Your Evening Report
NOTE: You can customize these settings on your watch or in your Garmin Connect™ account.
  1. From the watch face, hold Middle-left button.
  2. Select Watch Settings > Notifications & Alerts > Report Settings > Evening Report.
  3. Select an option:
    • Select Show Report to enable or disable the evening report.
    • Select Edit Report to customize the order and type of data that appears in your evening report.
    • Select Sleep Suggestion to enable or disable the sleep suggestion in your evening report.
    • Select Schedule Report to set the amount of time between the report and your sleep start (Setting Your Sleep Schedule).
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
