Adding a Stock
Before you can customize the stocks list, you must add the stocks glance to the glances list (Customizing the Glances List).
  1. From the watch face, press Lower-left button to view the stocks glance.
  2. Press Upper-right button.
  3. Select Edit > Add.
  4. Enter the company name or stock symbol for the stock you want to add, and select Check mark.
    The watch displays search results.
  5. Select the stock you want to add.
  6. Select the stock to view more information.
    TIP: To display the stock on the glances list, you can press Upper-right button, and select Set as Favorite.
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
