Starting a Workout
Your device can guide you through multiple steps in a workout.
  1. From the watch face, press Upper-right button.
    TIP: If you already have a scheduled or suggested workout for today, you can scroll down and select Workouts.
  2. Select Activities, and select an activity.
  3. Press Lower-left button, and select Training.
  4. Select an option:
    • To let the watch suggest a workout after you select your intensity and time targets, select Quick Workout.
    • To start an interval workout or to set a training target, select Targets & Intervals or Set a Target (Starting an Interval Workout, Setting a Training Target).
    • To start a saved workout, select Workout Library (Following a Workout From Garmin Connect).
      NOTE: To save a workout to your watch, you must download the workout from your Garmin Connect™ account and sync.
    • To start a scheduled workout from your Garmin Connect training calendar, select Training Calendar (About the Training Calendar).
    NOTE: Not all options are available for all activity types.
  5. Select a workout.
    NOTE: Only workouts that are compatible with the selected activity appear in the list.
  6. If necessary, select Do Workout.
  7. Press Upper-right button to start the activity timer.
After you begin a workout, the device displays each step of the workout, step notes (optional), the target (optional), and the current workout data.‍ For strength, yoga, cardio, or Pilates activities, an instructional animation appears.
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
