Navigating Back to Start
Before you can navigate back to start, you must locate satellites, start the timer, and start your activity.
At any time during your activity, you can return to your starting location. For example, if you are running in a new city, and you are unsure how to get back to the trail head or hotel, you can navigate back to your starting location. This feature is not available for all activities.
  1. Press Upper-right button .
  2. Select an activity that uses GPS, for example, Run.
  3. During your activity, hold Middle-left button.
  4. Select Navigate > Back to Start.
  5. Select TracBack or Straight Line.
    The navigation screen appears.
  6. Move forward.
    The arrow points toward your starting point.
    TIP: For more accurate navigation, orient your watch toward the direction in which you are navigating.
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
