Adding Contacts
You can add up to 50 contacts to the Garmin Connect™ app. Contact emails can be used with the LiveTrack feature. Three of these contacts can be used as assistance contacts (Adding Assistance Contacts).
  1. From the Garmin Connect app, select Menu.
  2. Select Contacts.
  3. Follow the on-screen instructions.
After you add contacts, you must sync your data to apply the changes to your Forerunner® device (Using the Garmin Connect App).
GUID-4A2FC8FE-7025-4AEC-946E-097B31131B45 v2
September 2026
