Descent T1 Device Care
NOTICE
Do not grip the regulator or the device to move, carry, or adjust the air tank.
NOTICE
Do not remove the safety plug from the base of the device.
NOTICE
Do not use a sharp object to clean the device.
NOTICE
Avoid chemical cleaners, solvents, and insect repellents that can damage plastic components and finishes.
NOTICE
Thoroughly rinse the device with fresh water after exposure to chlorine, salt water, sunscreen, cosmetics, alcohol, or other harsh chemicals. Prolonged exposure to these substances can damage the case.
NOTICE
Avoid extreme shock and harsh treatment, because it can degrade the life of the product.
NOTICE
Do not store the device where prolonged exposure to extreme temperatures can occur, because it can cause permanent damage.
NOTICE
Discontinue use if the device is damaged or if it is stored at a temperature outside the specified storage temperature range.
NOTICE
Discontinue use if there is water ingress into the battery compartment. Even small amounts of water can cause corrosion of the electrical contacts.
GUID-4A2D3019-BA14-49BD-B371-4214D187D493 v8
December 2025
