Adding Contacts
You can add up to 50 contacts to the Garmin Connect™ app. Contact emails can be used with the LiveTrack feature. Three of these contacts can be used as emergency contacts (Adding Emergency Contacts).
  1. From the Garmin Connect app, select Menu or Menu.
  2. Select Contacts.
  3. Follow the on-screen instructions.
After you add contacts, you must sync your data to apply the changes to your Descent™ Mk2i device (Manually Syncing Data with Garmin Connect).
GUID-4A2D3019-BA14-49BD-B371-4214D187D493 v8
December 2025
