Activity Map Settings
You can customize the appearance of the map data screen for each activity.
Hold MENU, select Activities & Apps, select an activity, select the activity settings, and select Map.
Configure Maps
Shows or hides data from installed map products.
Map Theme
Sets the map to display data optimized for your activity type. The System option uses the preferences from the system map settings (Map Themes).
Use Sys. Settings
Enables the device to use the preferences from the system map settings (Map Settings).
Orientation
Sets the orientation of the map. The North Up option shows north at the top of the screen. The Track Up option shows your current direction of travel at the top of the screen.
User Locations
Shows or hides saved locations on the map.
Auto Zoom
Automatically selects the zoom level for optimal use of your map. When disabled, you must zoom in or out manually.
Lock on Road
Locks the position icon, which represents your position on the map, onto the nearest road.
Track Log
Shows or hides the track log, or the path you have traveled, as a colored line on the map.
Track Color
Changes the track log color.
Detail
Sets the amount of detail shown on the map. Showing more detail may cause the map to redraw more slowly.
Marine
Sets the map to display data in marine mode (Marine Map Settings).
Draw Segments
Shows or hides segments, as a colored line on the map.
Draw Contours
Shows or hides contour lines on the map.
GUID-4A2D3019-BA14-49BD-B371-4214D187D493 v8
December 2025
