Adding Contacts
You can add up to 50 contacts to the Garmin Connect™ app. Contact emails can be used with the LiveTrack feature. Three of these contacts can be used as emergency contacts (Adding Emergency Contacts).
From the
Garmin Connect app, select
or
- Select Contacts.
- Follow the on-screen instructions.
After you add contacts, you must sync your data to apply the changes to your Descent™ Mk2i device (Manually Syncing Data with Garmin Connect).
Parent Topic: Safety and Tracking Features
