Changing the GPS Setting
For more information about GPS, go to garmin.com/aboutGPS.
  1. Hold MENU.
  2. Select Activities & Apps.
  3. Select an activity.
    NOTE: This feature is not available for all activities.
  4. Select the activity settings.
  5. Select GPS.
  6. Select an option:
    • Select Off to disable GPS for the activity.
    • Select GPS Only to enable the GPS satellite system.
    • Select GPS + GLONASS (Russian satellite system) for more accurate position information in situations with poor sky visibility.
      NOTE: Using GPS and another satellite system together can reduce battery life more quickly than using GPS only.
    • Select GPS + GALILEO (European Union satellite system) for more accurate position information in situations with poor sky visibility.
    • Select UltraTrac to record track points and sensor data less frequently.
      NOTE: Enabling the UltraTrac feature increases battery life but decreases the quality of recorded activities. You should use the UltraTrac feature for activities that demand longer battery life and for which frequent sensor data updates are less important.
GUID-4A2D3019-BA14-49BD-B371-4214D187D493 v7
May 2024
