Mounting the Sight on a Bow
- Align the large holes on the riser mount with the mounting holes on the side of your bow.
Using a 3 mm (1/8 in.) hex wrench, secure the riser mount using the included mounting screws
Tighten the mounting screws to a maximum torque specification of 6.7 N-m (60 lbf-in.).
NOTE: Do not exceed the bow manufacturer's recommended torque values.
- Slide the bow sight dovetail into the riser mount.
Using a 3.5 mm (9/64 in.) hex wrench, secure the bow sight to the riser mount with the included set screw
TIP: The bow sight dovetail includes two holes for the set screw. Mount the bow sight using the hole that functions best with your peep sight aperture. Mounting the sight closer to the bow may extend the sight aiming range in some cases. - Tighten the set screw to a maximum torque specification of 3.9 N-m (35 lbf-in.).
Parent Topic: Getting Started
