Securing the Remote Trigger Cable
Connect the remote trigger cable to the remote trigger port.
- Press the remote trigger cable into the port and rotate it clockwise until it locks into place.
Position the remote trigger
on the grip of your bow where you can comfortably activate it at full draw.
NOTE: You should confirm the trigger and the trigger cable are positioned so they do not interfere with the operation of the bow.
Secure the trigger to the bow using the included tape
TIP: You can use the extra piece of tape to secure the trigger cable to the riser.
Parent Topic: Getting Started
