Truck and Camper Pack
NOTE: The Truck and Camper Pack™ feature package is not available in North America.
In select regions, you can purchase the Truck and Camper Pack to unlock truck and RV navigation features and points of interest for your Garmin Drive™ navigator.
Unlocking the Truck and Camper Pack
NOTE: The Truck and Camper Pack features package is not available in North America.
  1. From the map, select Apps menu icon > Truck and Camper Pack™.
  2. Scan the QR code with your phone to learn more about the Truck and Camper Pack and purchase the premium features.
Vehicle Profiles
WARNING
Entering your vehicle profile characteristics does not guarantee that your vehicle's characteristics will be accounted for in all route suggestions or that you will receive the warning icons in all cases. Limitations may exist in the map data such that your device cannot account for these restrictions or road conditions in all cases. Always defer to all posted road signs and road conditions when making driving decisions.
By using different vehicle profiles, you can quickly change several device settings, such as which routing mode is used by default.
Routing and navigation are calculated differently based on your vehicle profile. The device avoids including restricted or impassable areas in routes based on the dimensions, weight, and other characteristics you entered for your vehicle.
The current active vehicle profile is indicated by an icon in the status bar. Some navigation and map settings on your device can be customized separately for each vehicle type.
Adding a Vehicle Profile
You can add a vehicle profile that includes the weight, dimensions, and other characteristics for your vehicle.
  1. From the home screen, select Apps menu icon > Settings > Vehicle Profile > Add icon.
  2. Select a vehicle type.
  3. Follow the on-screen instructions to enter the vehicle characteristics.
After you add a vehicle profile, you can edit the profile to enter additional detailed information, such as the vehicle identification number or trailer number.
Car Profile
The car profile is a preloaded vehicle profile intended for use in an automobile without a trailer. While using the car profile, the device calculates standard automobile routes, and routing for large vehicles is not available. Some features and settings specific to large vehicles are not available while using the car profile.
Switching the Vehicle Profile
Before you can change the vehicle profile, you must add a vehicle profile (Adding a Vehicle Profile).
  1. Select Apps menu icon.
  2. From the status bar, select the active vehicle profile 1.
    Vehicle profile location with a callout
  3. Select a vehicle profile.
    The vehicle profile information appears, including measurements and weight.
  4. Select Select Profile.
Editing a Vehicle Profile
You can edit a vehicle profile to change vehicle information or to add detailed information to a new vehicle profile, such as the vehicle identification number, trailer number, or odometer reading. You can also rename or delete a vehicle profile.
  1. From the home screen, select Apps menu icon > Settings > Vehicle Profile.
  2. Select the vehicle profile to edit.
  3. Select an option:
    • To edit the vehicle profile information, select Options, and select a field to edit.
    • To rename a vehicle profile, select Options > Context menu > Rename Profile.
    • To delete the vehicle profile, select Options > Context menu > Delete.
Vehicle and Driver Tools
Break Planning
When the break planning feature is enabled, the device notifies you one hour before suggested break times and drive hour limits and suggests break locations on your route. You can use this feature to keep track of your working hours, which may help you comply with safety regulations.
NOTE: Break planning features are not available when using the car vehicle profile.
Taking a Suggested Break
When it is time for a break, the device notifies you and displays suggested break location POIs along your route.
Select a POI from the list of suggested break locations.
The device adds the break location as the next destination on your route.
Starting the Break Timer
The break timer starts automatically when the vehicle is moving at least 8 kph (5 mph) for 30 seconds. You can start the timer manually at any time.
  1. From the map, select Apps menu icon > Break Planner.
  2. Select Start Timer.
Pausing and Resetting the Break Timer
The break timer pauses automatically when the vehicle stops for three minutes or longer. You can pause the timer manually for brief stops, such as parking or stopping at a truck stop. At the end of your drive, you can manually reset the timer.
  1. Select Stop Timer.
  2. Select an option:
    • To pause the timer, select Pause.
    • To stop and reset the timer, select Reset.
Adjusting Drive Hours
You can adjust your total hours driven to more closely match your hours of service records.
  1. While using the break planner feature, select Total Hours Driven.
  2. Enter the total hours driven.
  3. Select Save.
Logging Service History
You can log the date and odometer reading when service or maintenance is performed on your vehicle. The device provides several service categories, and you can add custom categories (Adding Service Categories).
  1. Select Apps menu icon > Service History.
  2. Select a service category.
  3. Select Add Record.
  4. Enter the odometer reading, and select Check.
  5. Enter a comment (optional).
  6. Select Check.
  2. Select Context menu > Add Category.
  3. Enter a category name, and select Check.
Deleting Service Categories
When you delete a service category, all service records in the category are also deleted.
  2. Select Context menu > Delete Categories.
  3. Select the service categories to delete.
  4. Select Delete.
Deleting Service Records
  3. Select Context menu > Delete Records.
  4. Select the service records to be deleted.
  5. Select Delete.
Editing a Service Record
You can edit the comment, odometer reading, and date of a service record.
  2. Select a category.
  3. Select a field.
  4. Enter the new information, and select Check.
dēzl DualView
You can remotely control a compatible dēzl™ DualView side camera system and customize settings using your Garmin® navigator. Go to garmin.com for more information about the dēzl DualView side camera system.
Viewing Popular Truck Paths on the Map
You can enable the device to highlight popular truck paths on the map. This can be useful to help you choose roads that are more accessible for your vehicle.
From the map, select Map layers > Popular Truck Paths.
Planning Your Arrival
Before you start a route, you can plan to arrive at a popular truck destination, such as a loading dock or truck parking, at the end of your route. You can also add your own destinations to the map.
  1. Select Where To?, and search for a location (Finding and Saving Locations).
  2. Select a location.
  3. Select Plan Arrival.
    A preview of your destination appears on the map. Popular truck destinations appear next to the map. If your Garmin Drive device is paired with the Garmin Drive app, it downloads satellite imagery automatically.
  4. Select a destination, and select Go!.
Satellite Imagery
The Satellite Imagery app provides downloadable, high-resolution map imagery. You can download satellite imagery directly to your device while it is connected to a Wi‑Fi® network.
Downloading Satellite Imagery
Before you can download satellite imagery directly to your device, you must connect your device to a wireless network (Connecting to a Wi‑Fi Network).
  1. Select Apps menu icon > Satellite Imagery > Download Satellite Imagery.
  2. If necessary, select Location, and search for a location.
  3. Zoom and scroll the map to show the area where you want to view satellite imagery.
  4. Select an option:
    • To change the imagery detail level, select Detail, and select a detail level.
    • To change the size of the map, select Size, and enter a size.
    • To change the storage location for your downloaded files, select Save To, and select a storage location.
  5. Select Download.
GUID-42646542-B741-4342-8239-2F50A7A36546 v1
September 2026
