Using the Audio Mixer
You can use the audio mixer to set the relative volume levels for different audio sources, such as navigation prompts, voice-activated feature responses, or alerts. The level for each audio type is a percentage of the master volume.
  1. Select Apps menu icon > Volume > Mixer.
  2. Use the slider bars to adjust the relative volume for each audio source.
    For example, when a slider bar is set to the far right position, that audio source plays at the master volume level. When a slider bar is set to the center position, it plays at half the master volume level.
GUID-42646542-B741-4342-8239-2F50A7A36546 v1
September 2026
