Your Route on the Map
As you travel, the device guides you to your destination using voice prompts and information on the map. Instructions for your next turn or exit, or other actions appear across the top of the map.
Search. Select to start a new route or add a stop to your active route. |
Distance to the next action and the name of the street or exit associated with the next action. |
Next action in the route. Indicates the next turn, exit, or other action and the lane in which you should travel, if available. |
Route highlighted on the map with an arrow indicating the next action in the route. Icons appear along your route to indicate traffic light and stop sign locations. |
Vehicle speed and speed limit. |
Name of the road on which you are traveling. |
Select to see an overview of your current route. |
Stops your current route. |
