Controlling Music Playback on a Bluetooth Device
  1. Select the BLUETOOTH source.
  2. Select menu symbol > DISCOVERABLE to make the stereo visible to your compatible Bluetooth® device.
    NOTE: The stereo is discoverable for only two minutes to prevent interruption to audio streaming over Bluetooth wireless. If more than two minutes pass before you connect a compatible device, you must repeat this step.
  3. Enable Bluetooth on your compatible Bluetooth device.
  4. Bring the compatible Bluetooth device within 10 m (33 ft.) of the stereo.
  5. On the Bluetooth device, search for Bluetooth devices.
  6. Select the stereo from the list of detected devices.
  7. Follow the on-screen directions to connect to the discovered stereo.
    When pairing, your compatible Bluetooth device may ask you to confirm a code on the remote control. The remote control does not display a code, but it connects correctly when you confirm the message on the compatible Bluetooth device.
  8. Use the controls on the remote control to control the music playback.
GUID-40B6D96C-6847-408F-9CFD-3AD6713BC4B9 v1
August 2026
