Select to turn on the device.
Select to mute and un-mute the audio.
Hold to turn off the remote and stereo.
Select to cycle the available sources.
TIP:
You can use the dial to browse and select the source when the available sources are shown.
Hold to switch from remote control mode to
NMEA 2000® mode.
BLUETOOTH or
USB: Select to pause or resume the current track.
AM/FM: Select to cycle through the tuning modes (auto, manual, and presets).
DAB: Select to scan for DAB stations.
BLUETOOTH or
USB: Select to skip to the beginning of the track or to the previous track.
AM/ FM:
Auto or manual tuning: Select to tune to the previous station.
Hold for faster station skipping in manual mode.
Presets: Select to change to the previous preset.
AUX: Select to decrease the gain for the connected source.
DAB: Select to return to the previous DAB station in the ensemble. When you reach the beginning of the current ensemble, the stereo automatically changes to the last available station in the previous ensemble.
BLUETOOTH or
USB: Select to skip to the next track.
AM/ FM:
Auto or manual tuning: Select to tune to the next station.
Presets: Select to change to the next preset.
AUX: Select to increase the gain for the connected source.
DAB: Select to advance to the next DAB station in the ensemble. When you reach the end of the current ensemble, the stereo automatically changes to the first available station in the next ensemble.
Dial
Turn to adjust the volume, move through the menus, or adjust a setting.
Press to select an option or a setting.
