General Settings
Select .
- ZONE
Enables you to configure the speaker zones.
Adjusts the bass, middle, and treble tones.
- LCD
Sets the brightness and contrast.
- POWER SAVE
Enables and disables the backlight power-save feature.
- KEY SOUND
Enables and disables the sound.
- WAKE WITH STEREO
Turns on the remote when the stereo is turned on by an MFD.
- NMEA MONITOR
Sets the data to view, the data display cycle, and the units of measure for NMEA 2000® data from a connected compatible multi-function display (MFD).
- LANGUAGE
Sets the language used on the remote.
- TUNER REGION
Sets the region used by the FM, AM, or DAB source.
- TEL/MUTE
Sets the behavior of the mute wire. The device can either mute the audio or switch to the AUX input when the optional mute wire is activated.
- ARTWORK
Shows or hides the album cover artwork on a connected compatible multi-function display (MFD).
NOTE: Album art cannot be shown on a remote control or when the media player is connected using Bluetooth® technology. - SOURCES
Remove sources you do not want to see in the source list.
- SET DEVICE NAME
Assigns a name to a connected stereo.
- STEREO
Assigns the remote control to a connected stereo.
- UPDATE
Updates the connected stereo, remote control, or accessory.
Resets the connected stereo settings to factory default values.
- ABOUT
Shows the installed software version of the entertainment system and the remote.
