Setting the Tuner Region
You must select the region you are in to receive AM and FM stations properly.
If you are connected to a compatible DAB module and antenna (not included), you must select the region you are in to receive DAB stations properly.
NOTE:
DAB stations are not available in all regions.
- Select .
- Select the region you are in.
Parent Topic: Radio
