Setting up Speaker Zones
  1. Select menu symbol > SETTINGS > ZONE.
  2. Select a zone.
  3. Select one or more options:
    NOTE: Not all options are available for all zones.
    • To link zones 1 and 2, select LINK TO ZONE 1 to fill the option button (zone 2 only).
    • To adjust the right and left speaker balance of this zone, select BALANCE, and use the dial to set the balance.
    • To limit the maximum volume output of this zone, select VOLUME LIMIT, and use the dial to set the limit.
    • To set the subwoofer filter, select SUB FILTER, and use the dial to set the filter (zone 1 only).
    • To set the subwoofer level, select SUB LEVEL, and use the dial to set the level (zone 1 only).
      TIP: To open the subwoofer level from any screen, press and hold the dial for three seconds.
    • To give the zone a specific name, select SET ZONE NAME (Entering Text).
GUID-40B6D96C-6847-408F-9CFD-3AD6713BC4B9 v1
August 2026
