Connecting a Spy Pole Mount to a Garmin Chartplotter
A Spy Pole™ mount can connect to one compatible Garmin® chartplotter at a time. After connecting a Spy Pole™ mount to a chartplotter, you can control it using any other chartplotter connected to the same Garmin BlueNet™ or Garmin Marine Network.
Up to four Spy Pole™ mounts can connect to a Garmin BlueNet or Garmin Marine Network at the same time.
  1. Turn on the Spy Pole™ mount.
  2. Press Power button on the Spy Pole™ mount three times.
    The LED turns solid blue, indicating that the device is ready to connect.
  3. On the chartplotter, select Home > Settings > Communications > Wireless Devices > Spy™ Pole Mount > Start.
  4. Wait for the chartplotter to connect to the Spy Pole™ mount.
    The LED on the Spy Pole™ mount turns green again after the devices are connected successfully.
After you connect a Spy Pole™ mount to a chartplotter successfully, you are prompted to complete the setup wizard on the chartplotter screen. It is highly recommended to complete the wizard at this time for the best results.
September 2026
