Pairing Spy Pole Accessories
A Spy Pole™ mount is paired with a Spy Pole™ gesture remote, a Spy Pole™ foot control, and a Spy Pole™ heading sensor at the factory. If you replace one of these accessories or add additional control accessories, you must pair them to the Spy Pole™ mount.
You can pair up to five Spy Pole™ gesture remotes with one Spy Pole™ mount at a time. You can pair only one Spy Pole™ foot control and one Spy Pole™ heading sensor to one Spy Pole™ mount at a time.
If you have multiple Spy Pole™ mounts installed on the boat, one Spy Pole™ heading sensor can connect to up to four Spy Pole™ mounts.
  1. Turn on the Spy Pole™ mount.
  2. Press Power button on the Spy Pole™ mount three times.
    The LED turns solid blue, indicating that the device is pairing.
  3. Select an option depending on the type of accessory you are pairing to the Spy Pole™ mount:
    • To pair a Spy Pole™ gesture remote, press the left and right buttons on the remote simultaneously three times.
    • To pair a Spy Pole™ foot control, press the top two programmable buttons on the foot control simultaneously three times.
    • To pair a Spy Pole™ heading sensor, press the button on the heading sensor three times.
    The LED on the gesture remote or foot control flashes blue, or the LED on the heading sensor turns solid blue, indicating that the device is pairing.
  4. Wait for the accessory to connect to the Spy Pole™ mount.
    The LED on the Spy Pole™ mount turns green, and the LED on the accessory flashes green after the devices are paired successfully.
  5. Repeat this procedure for any additional accessories you want to pair with the Spy Pole™ mount.
September 2026
