GPSMAP 12x3 Specifications
Dimensions (W × H × D)
308.3 × 227.6 × 81.8 mm (12 1/8 × 8 15/16 × 3 1/4 in.)
Dimensions with cover on bail mount (W × H × D)
327.2 × 246.3 × 113.8 mm (127/8 × 911/16 × 41/2 in.)
Clearance to next obstruction behind chartplotter
93.6 mm (311/16 in.)
Display size (W × H)
262.1 × 164.2 mm (10 15/16 × 6 7/16 in.)
30.7 cm (12.1 in.) diagonal
Display resolution
WXGA, 1280 × 800 pixels
Weight
3.0 kg (6.6 lb.)
Compass-safe distance
45 cm (17.72 in.)
Max. power usage at 10 Vdc
Non-sonar models: 26.5 W
Sonar models: 43.0 W
Typical current draw at 12 Vdc
Non-sonar models: 1.67 A
Sonar models: 1.68 A
Max. current draw at 12 Vdc
Non-sonar models: 2.15 A
Sonar models: 3.56 A
Temperature range
From -15° to 55°C (from 5° to 131°F)
Material
Polycarbonate plastic and die-cast aluminum
Water rating
IEC 60529 IPX7 1
Input voltage
From 10 to 32 Vdc
Fuse
6 A, 125 V fast-acting
NMEA 2000® LEN @ 9 Vdc
2
NMEA 2000 draw
75 mA max.
Max. waypoints
5,000
Max. routes
100
Max. active track points
50,000 points, 50 saved tracks
Wireless frequency
2.4 GHz @ 18.3 dBm max.
Memory card
2 microSD® memory card slots, 32 GB max card size2.
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
2 As of software version 34.00, you can connect an external USB card reader to a GPSMAP® 7x3, 9x3, and 12x3 series chartplotter and use a memory card up to a 1 TB, formatted to exFAT with speed class 10 or higher.
September 2026
